SH7203入门套件在加速代码开发和减少上市时间上已经成熟。An Renesas Starter Kit+, as the name suggests, is a complete development kit for Renesas microcontrollers. On-board Memory[/td][td]Flash Memory (S29GL032A11TFIR23): 4 MB[/td][/tr][tr][td]SDRAM (K4S281632I-UC75): 16 MB[/td][/tr][tr][td=1,4]Input Clock[/td][td]Main: 16.6675 MHz[/td][/tr][tr][td]Sub: 32.768 kHz[/td][/tr][tr][td]SSI: 24.576 MHz[/td][/tr][tr][td]USB: 48 MHz[/td][/tr][tr][td]Potentiometer[/td][td]Single-turn, 10 kΩ[/td][/tr][tr][td=1,2]LED[/td][td]Power indicator: green x 1[/td][/tr][tr][td]User: green x 1, orange x 1, red x 2[/td][/tr][tr][td=1,2]Switch[/td][td]Reset x 1[/td][/tr][tr][td]User x 3[/td][/tr][tr][td]DIP Switch[/td][td]10-pole x 4[/td][/tr][tr][td=1,2]DC Power Jack[/td][td]8 V to 15 V Input: Jumpers SEL_5VA and SEL_5VB Fitted (Default setting)[/td][/tr][tr][td]5 V Input: Jumpers SEL_5VA and SEL_5VB Removed[/td][/tr][tr][td=1,2]E10A-USB Connector[/td][td]Without AUD Function: 14-pin box header[/td][/tr][tr][td]With AUD Function: 36-pin, Mini-D Ribbon Connector, Right angle[/td][/tr][tr][td]RS232 Serial Connector[/td][td]9-pin DSUB[/td][/tr][tr][td]Ethernet Connector[/td][td]RJ45[/td][/tr][tr][td]SSI Connector[/td][td]2.54 mm pitch, 5-pin, Right angle[/td][/tr][tr][td]LCD Display Connector[/td][td]14-pin socket[/td][/tr][tr][td=1,2]LCD Panel Connector[/td][td]Hitachi 2.2" QVGA TFT: 0.3mm pitch, 39-pin (J4)[/td][/tr][tr][td]Generic LCD: 2.54 mm pitch, 40-pin (J14)[/td][/tr][tr][td]RCAN-TL1 Connector[/td][td]2.54 mm pitch, 3-pin x 2 (CAN Bus line x 2, Ground x 1)[/td][/tr][tr][td=1,2]USB Connector[/td][td]Host: USB-A[/td][/tr][tr][td]Function: USB-B[/td][/tr][tr][td]Application Board Interface[/td][td]2.54 mm pitch, 26-pin x 2 (JA1, JA2), 24-pin x 2 (JA5, JA6)[/td][/tr][tr][td]BUS Interface[/td][td]2.54 mm pitch, 50-pin (JA3)[/td][/tr][/table]* AUD: Advanced User Debugger* RCAN-TL1: Renesas CAN Time Trigger Level 1* SSI: Serial Sound Interface* The potentiometer is fitted to offer an easy way of supplying a variable analog input to the controller. It does not necessarily reflect the accuracy of the controllers ADC. Please see the device manual for details.Manufacturer Name: PIHER INTERNATIONAL CORPORATIONPart Number: N6R (6 mm RoHS reflowable potentiometer)<a href="http://cn.renesas.com/products/tools/introductory_evaluation_tools/renesas_starter_kits/rsk_plus_sh7203/index.jsp#siteHeader">Top
Configuration
- CPU Board
- Detachable LCD Display Module
- Detachable AD Adjustment Shaft
- USB Host & Function Connection
- SMSC Ethernet Interface
- Hitachi 2.2” QVGA TFT Display
- E10A-USB for Starter Kit
- Connection Cable (USB Cable, User Interface Cable)
- 128 MB USB FLASH Memory Stick
- Ethernet cross-wired cable
- Multi region 12 V power supply
- Quick Start Guide
- CD-ROM- Documents: User Manual, Tutorial and more- IDE: High-performance Embedded Workshop- C/C++ Compiler: C/C++ Compiler Package for SuperH Family Evaluation Version- Debugger: E10A-USB Emulator Debugger
Notes
- E10A-USB for Starter Kit is a special emulator for only Renesas Starter Kit+ products.
- The C/C++ Compiler Package for SuperH Family Evaluation Version does not come with technical support services. In addition, the C/C++ Compiler Package for SuperH Family Evaluation Version has some restrictions compared to the Product Version.Trial period: 60 daysThe link size will be limited to 256 KB after 60 days
Top
PC System Requirements
- IBM PC/AT or compatible PC (USB interface necessary) *1
- Intel Pentium III 600 MHz or higher *3
- Memory 128 MB or higher
- Microsoft Windows 2000/XP *2
下载连接:
SH7203入门套件用户指南
SH7203入门套件快速入门指南
SH7203入门套件指导手册 |
