查看: 1381|回复: 0
SH7269入门套件
发表于 2012-8-31 15:28:46 | 显示全部楼层 |阅读模式
SH7269入门套件在加速代码开发和减少上市时间上已经成熟。An Renesas Starter Kit+, as the name suggests, is a complete development kit for Renesas microcontrollers. On-board Memory[/td][td]SDRAM[/td][/tr][tr][td]NOR Flash[/td][/tr][tr][td]NAND Flash[/td][/tr][tr][td]QSPI Flash[/td][/tr][tr][td=1,5]Input Clock[/td][td]Main: 13.225 MHz[/td][/tr][tr][td]RTC: 32.768 kHz[/td][/tr][tr][td]USB: 48 MHz[/td][/tr][tr][td]AUDIO: 24.576 MHz[/td][/tr][tr][td]VIDEO: 27 MHz[/td][/tr][tr][td]Potentiometer[/td][td]Single-turn, 10 kΩ[/td][/tr][tr][td=1,3]LED[/td][td]Power indicator: green x 2[/td][/tr][tr][td]User: green x 1, orange x 1, red x 2[/td][/tr][tr][td]Ethernet: SPEED x 1, LINK x 1, DUPLEX x 1[/td][/tr][tr][td=1,2]Switch[/td][td]Reset x 1[/td][/tr][tr][td]User x 3[/td][/tr][tr][td]DIP Switch[/td][td]4-pole x 2[/td][/tr][tr][td]DC Power Jack[/td][td]7-15 V Input or 5 V Input[/td][/tr][tr][td=1,2]E10A-USB Header[/td][td]Without AUD Function: 14-pin box header[/td][/tr][tr][td]With AUD Function: 38-pin Mictor Connector[/td][/tr][tr][td]CAN Connector[/td][td]2.54 mm pitch, 3-pin x 2 (CAN BUS line x 2, GND x 1)[/td][/tr][tr][td=1,2]USB Connector[/td][td]Host: USB-A[/td][/tr][tr][td]Function: USB-MiniB[/td][/tr][tr][td]RS232 Serial Connector[/td][td]9-pin DSUB[/td][/tr][tr][td]LCD Display Connector[/td][td]14-pin socket[/td][/tr][tr][td=1,3]LCD Panel connector[/td][td]Onboard TFT[/td][/tr][tr][td]External TFT Board[/td][/tr][tr][td]Generic LCD[/td][/tr][tr][td]Ethernet Connector[/td][td]RJ45[/td][/tr][tr][td]Compsite Input[/td][td]VIDEO1, VIDEO2[/td][/tr][tr][td]DVI Over HDMI Interface[/td][td]HDMI Connector[/td][/tr][tr][td=1,2]Audio Jack[/td][td]Audio Input[/td][/tr][tr][td]Audio Output[/td][/tr][tr][td=1,3]Misc. Audio Connecors[/td][td]Sound Generator[/td][/tr][tr][td]Serial Sound[/td][/tr][tr][td]S/PDIF[/td][/tr][tr][td]SD/MMC Card[/td][td]Common SD/MMC Connector[/td][/tr][tr][td]Misc. Header[/td][td]2.54 mm pich, 14-pin[/td][/tr][tr][td]Application Board Interface[/td][td]2.54 mm pitch, 26-pin x 2 (JA1, JA2), 24-pin x 2 (JA5, JA6)[/td][/tr][tr][td]BUS Interface Option[/td][td]2.54 mm pitch, 50-pin (JA3)[/td][/tr][/table]* The potentiometer is fitted to offer an easy way of supplying a variable analog input to the controller. It does not necessarily reflect the accuracy of the controllers ADC. Please see the device manual for details.Manufacturer Name: PIHER INTERNATIONAL CORPORATIONPart Number: N6R (6 mm RoHS reflowable potentiometer) <a name="config">Configuration
  • CPU Board
  • Detachable LCD Display Module
  • Detachable AD Adjustment Shaft
  • E10A-USB for Starter Kit
  • NEC LCD Technologies 3.5 SVGA TFT Display
  • Connection Cable (USB Cable, User Interface Cable)
  • Multi region 5 V power supply
  • Quick Start Guide
  • CD-ROM- Documents: User Manual, Tutorial and more- IDE: High-performance Embedded Workshop- C/C++ Compiler: C/C++ Compiler Package for SuperH Family Evaluation Version- Debugger: E10A-USB Emulator Debugger
Notes
  • E10A-USB for Starter Kit is a special emulator for only Renesas Starter Kit+ products. The C/C++ Compiler *Package for SuperH Family Evaluation Version does not come with technical support services. In addition, the C/C++ Compiler Package for SuperH Family Evaluation Version has some restrictions compared to the Product Version.Trial period: 60 daysThe link size will be limited to 256 KB after 60 days
PC System Requirements
  • IBM PC/AT or compatible PC (USB interface necessary) *1
  • Intel Pentium III 600 MHz or higher *3
  • Memory 128 MB or higher
  • Microsoft Windows 7/Windows XP/Windows Vista *2
下载连接:
SH7269入门套件用户指南
SH7269入门套件指导手册
SH7269入门套件快速入门指南
GMT+8, 2024-11-26 23:45 , Processed in 0.100730 second(s), 15 queries , MemCache On.
