SH7264入门套件在加速代码开发和减少上市时间上已经成熟。An Renesas Starter Kit+, as the name suggests, is a complete development kit for Renesas microcontrollers. On-board Memory[/td][td]Serial Flash (M25PX64): 64 Mbit[/td][/tr][tr][td]NAND Flash (K9NBG08U5M-PCB0): 8 Gbit[/td][/tr][tr][td]NOR Flash (S29GL512P-10T-AIR20): 512 Mbit[/td][/tr][tr][td]SDRAM (IS42S16320B-7TL): 64 MB[/td][/tr][tr][td=1,7]Input Clock[/td][td]Main: 18 MHz[/td][/tr][tr][td]Sub: 32.768 kHz[/td][/tr][tr][td]LCD: 25.175 MHz[/td][/tr][tr][td]USB: 48 MHz[/td][/tr][tr][td]Video Decoder: 24.576 MHz[/td][/tr][tr][td]External DAC/ADC (for CODEC): 13 MHz[/td][/tr][tr][td]Ethernet (for PHY): 25 MHz[/td][/tr][tr][td]Potentiometer[/td][td]Single-turn, 10 kΩ[/td][/tr][tr][td=1,3]LED[/td][td]5 V Power indicator: blue x 1[/td][/tr][tr][td]3.3 V Power indicator: green x 1[/td][/tr][tr][td]User: yellow x 3[/td][/tr][tr][td=1,2]Switch[/td][td]Reset x 1[/td][/tr][tr][td]User x 16[/td][/tr][tr][td]DC Power Jack[/td][td]5 V Input[/td][/tr][tr][td]E10A-USB Header[/td][td]14-pin box header[/td][/tr][tr][td]RS232 Serial Connector[/td][td]9-pin DSUB[/td][/tr][tr][td]LCD Display Connector[/td][td]14-pin socket[/td][/tr][tr][td=1,2]TFT-LCD Panel Connector[/td][td]Hitatch 2.2'' QVGA TFT: 39-pin (CN11)[/td][/tr][tr][td]Generic LCD: 30-pin (JP12)[/td][/tr][tr][td]USB Connector[/td][td]Socket-A & Mini-B[/td][/tr][tr][td]CAN Connector[/td][td]2.54 mm pitch, 3-pin (CAN Bus line x 2, Ground x 1)[/td][/tr][tr][td]Ethernet Connector[/td][td]RJ45[/td][/tr][tr][td]SD Card Connector[/td][td]Reverse Type[/td][/tr][tr][td]Audio Jack[/td][td]Headphone & Speaker[/td][/tr][tr][td]Video Jack[/td][td]Compsite & Separate[/td][/tr][tr][td]VGA Connector[/td][td]DB15H[/td][/tr][tr][td]Microcontroller Pin Header[/td][td]56-pin (JP15), 32-pin (JP16)[/td][/tr][/table]<a href="http://cn.renesas.com/products/tools/introductory_evaluation_tools/renesas_starter_kits/rsk_plus_sh7264/index.jsp#siteHeader">Top
Configuration
- CPU Board
- Detachable LCD Display Module
- Detachable AD Adjustment Shaft
- Hitachi 2.2” QVGA TFT Display
- E10A-USB for Starter Kit
- Connection Cable (USB Cable, User Interface Cable)
- Multi region 5 V power supply
- Quick Start Guide
- CD-ROM- Documents: User Manual, Tutorial and more- IDE: High-performance Embedded Workshop- C/C++ Compiler: C/C++ Compiler Package for SuperH Family Evaluation Version- Debugger: E10A-USB Emulator Debugger
Notes
- E10A-USB for Starter Kit is a special emulator for only Renesas Starter Kit+ products.
- The C/C++ Compiler Package for SuperH Family Evaluation Version does not come with technical support services. In addition, the C/C++ Compiler Package for SuperH Family Evaluation Version has some restrictions compared to the Product Version.Trial period: 60 daysThe link size will be limited to 256 KB after 60 days
Top
PC System Requirements
- IBM PC/AT or compatible PC (USB interface necessary) *1
- Intel Pentium III 600 MHz or higher *3
- Memory 128 MB or higher
- Microsoft Windows 2000/ Windows XP/Windows Vista *2
下载连接:
SH7264入门套件用户指南
SH7264入门套件指导手册
SH7264入门套件快速入门指南 |
