查看: 1412|回复: 0
RX210 入门套件
发表于 2012-8-31 14:17:56 | 显示全部楼层 |阅读模式
RX210入门套件是易于操作的 RX210微控制器入门和评估工具。 The board also provides a useful platform for evaluating the Renesas suite of development tools for coding and debugging, using High-performance Embedded Workshop as well as programming the device using E1 emulator and/or Flash Development Toolkit.The Renesas Starter Kit for RX210 may be connected to the host PC using a simple RS232 serial connection or via the included USB E1 on chip debugging interface.The purpose of the board is to enable the user to evaluate the capabilities of the device and its peripherals by giving the user a simple platform on which code can be run only minutes from opening box. It can also prove an invaluable tool in development by providing a useful test platform for code already debugged using one of our more powerful emulation tools.To customers who use Windows 7 (64-bit edition)
When using an installer of this product on a PC which includes Windows 7 (64-bit edition), you may experience a problem where the E1 emulator cannot be used because the USB driver for the E1 emulator is not installed. In this case please install the USB driver according to the following procedure.
  • Use the attached installer of this product and complete the installation.
  • Download after Renesas E-Series USB driver V.1.02 Release 00 from the E1 emulator product page (http://www.renesas.com/e1_download).
  • Execute the downloaded USB driver and start the installation.
  • The installation confirmation screen of the device software is displayed during the installation. Click the <Install> button to install the USB driver.
  • When the installation is completed, connect the E1 emulator to the PC. The USB driver is automatically installed and the E1 emulator can be used.
Block Diagram
Layout and Specification
The LCD display module is supplied as a detachable sub-board. The board dimensions are 120 mm by 100 mm, detailed dimensions are available in the user manual.ItemSpecificationMicrocontrollerR5F52108ADFPInput ClockMain: 20 MHzSub: 32.768 kHzPotentiometerSingle-turn, 10 kΩLEDPower indicator: green x 1User: green x 1, orange x 1, red x 2SwitchReset x 1User x 3DC Power Jack5 V InputE1 Header14-pin box headerRS232 Serial Connector9-pin DSUBLCD Display Connector14-pin socketMicrocontroller Pin Header2.54 mm pitch, 36-pin x 4 (J1, J2, J3, J4)Application Board Interface2.54 mm pitch, 26-pin x 2 (JA1, JA2), 24-pin x 2 (JA5, JA6)BUS Interface Option2.54 mm pitch, 50-pin (JA3)* Microcontroller Pin Header, Application Board Interface and BUS Interface Option are not contained in the product.* The potentiometer is fitted to offer an easy way of supplying a variable analog input to the controller. It does not necessarily reflect the accuracy of the controllers ADC. Please see the device manual for details.Manufacturer Name: PIHER INTERNATIONAL CORPORATIONPart Number: N6R (6 mm RoHS reflowable potentiometer)
Configuration
  • CPU Board
  • Detachable LCD Display Module
  • Detachable AD Adjustment Shaft
  • E1 Emulator
  • Connection Cable (USB Cable, User Interface Cable)
  • Quick Start Guide
  • CD-ROM- Documents: User Manual, Tutorial, and more- IDE: High-performance Embedded Workshop- C Compiler: C/C++ Compiler Package for RX Family Evaluation Version- Debugger: E1/E20 Emulator Debugger
Notes
  • The C/C++ Compiler Package for RX Family Evaluation Version does not come with technical support services. In addition, The C/C++ Compiler Package for RX Family Evaluation Version has some restrictions compared to the Product Version.Trial period: 60 daysThe link size will be limited to 128 KB after 60 days.
PC System Requirements
  • IBM PC/AT or compatible PC (USB interface necessary) *1
  • Intel Pentium Ⅲ 600 MHz or higher *3
  • Memory 128 MB or higher
  • Microsoft Windows 7 / Windows XP / Windows Vista *2
下载连接:
RX210 入门套件用户指南
RX210 入门套件指导手册
RX210 入门套件快速入门指南
GMT+8, 2024-11-26 23:44 , Processed in 0.105985 second(s), 15 queries , MemCache On.
