RX630入门套件是易于操作的RX630微控制器入门和评估工具。 The kit also provides a useful platform for evaluating the Renesas suite of development tools for coding and debugging. This includes a choice of IDEs between the High-performance Embedded Workshop and e2studio.The Renesas Starter Kit for RX630 may be connected to the host PC using a simple RS232 serial connection or via the included USB E1 on chip debugging interface.The purpose of the board is to enable the user to evaluate the capabilities of the device and its peripherals by giving the user a simple platform on which code can be run only minutes from opening box. It can also prove an invaluable tool in development by providing a useful test platform for code already debugged using one of our more powerful emulation tools. Block Diagram
Layout and Specification
The LCD display module is supplied as a detachable sub-board. The board dimensions are 120 mm by 100 mm, detailed dimensions are available in the user manual. ItemSpecificationMicrocontrollerR5F5630EDDFPInput ClockMain: 12 MHzSub: 32.768 kHzPotentiometerSingle-turn, 10 kΩLEDPower indicator: green x 1User: green x 1, orange x 1, red x 2SwitchReset x 1User x 3DC Power Jack5 V InputBattery HolderCR2032E1 Header14-pin box headerCAN Connector2.54 mm pitch, 3-pin (CAN BUS line x 2, GND x 1)USB ConnectorFunction: USB-MiniBRS232 Serial Connector9-pin DSUBLCD Display Connector14-pin socketMicrocontroller Pin Header2.54 mm pitch, 36-pin x 4 (J1, J2, J3, J4)Application Board Interface2.54 mm pitch, 26-pin x 2 (JA1, JA2), 24-pin x 2 (JA5, JA6)BUS Interface Option2.54 mm pitch, 50-pin (JA3)* Microcontroller Pin Header, Application Board Interface, BUS Interface Option and Coin Cell are not contained in the product.* The potentiometer is fitted to offer an easy way of supplying a variable analog input to the controller. It does not necessarily reflect the accuracy of the controllers ADC. Please see the device manual for details.Manufacturer Name: PIHER INTERNATIONAL CORPORATIONPart Number: N6R (6 mm RoHS reflowable potentiometer) Configuration
- CPU Board
- Detachable LCD Display Module
- Detachable AD Adjustment Shaft
- E1 Emulator
- Connection Cable (USB Cable, User Interface Cable)
- Quick Start Guide
- 2 CD-ROMs[1]- Documents: User Manual, Tutorial, and more- IDE: High-performance Embedded Workshop- C Compiler: C/C++ Compiler Package for RX Family Evaluation Version- Debugger: E1/E20 Emulator Debugger[2]- Documents: User Manual, Tutorial, and more- IDE: Eclipse e2studio- C Compiler: C/C++ Compiler Package for RX Family Evaluation Version- Debugger: E1/E20 Emulator Debugger
Notes
- The C/C++ Compiler Package for RX Family Evaluation Version does not come with technical support services. In addition, The C/C++ Compiler Package for RX Family Evaluation Version has some restrictions compared to the Product Version.Trial period: 60 daysThe link size will be limited to 128 KB after 60 days.
PC System Requirements
- IBM PC/AT or compatible PC (USB interface necessary) *1
- Intel Pentium Ⅲ 600 MHz or higher *3
- Memory 128 MB or higher
- Microsoft Windows 7/ Windows XP / Windows Vista *2
*1: IBM and PC/AT are registered trademarks of International Business Machines Corporation of the U.S.*2: MS, MS-DOS and Windows are registered trademarks of Microsoft Corporation of the U.S. No support for Windows Vista® 64-bit editions.*3: Pentium is a trademark of Intel Corporation of the U.S.
下载连接:
RX630入门套件用户指南
RX630入门套件指导手册
RX630入门套件快速入门指南 |
