查看: 1424|回复: 0
RX62N入门套件
发表于 2012-8-31 13:41:23 | 显示全部楼层 |阅读模式
RX62N入门套件在加速代码开发和减少上市时间上已经成熟。An Renesas Starter Kit+, as the name suggests, is a complete development kit for Renesas microcontrollers.Block Diagram
Layout and Specification
The LCD display module is supplied as a detachable sub-board. The board dimensions are 150 mm by 180 mm, detailed dimensions are available in the user manual.ItemSpecificationMicrocontrollerR5F562N8BDBGOn-board MemorySDRAM (K4S281632I-UC75): 128 MbitI2C EEPROM (AT24C16AN-10SU-2.7): 16 KbitSPI Serial Flash (SST25VF016B-50-4C-S2AF): 16 MbitInput ClockMain: 12 MHzSub: 32.768 kHzEthernet (for PHY): 25 MHzPotentiometerSingle-turn, 10 kΩLED5 V Power Indicator: green x 13.3 V Power Indicator: green x 1User: green x 1, orange x 1, red x 2Ethernet Status: green x 3, yellow x 1SwitchReset x 1User x 3DIP Switch4-pole x 1DC Power Jack7 V to 15 V Input: Jumpers J10 and J11 opened (Default)5 V Input: Jumpers J10 and J11 shortedUSB Power Jack5 V Input: 2-pin header3.3 V Input: 2-pin headerE1 Connector14-pin box headerE20 Connector38-pin Mictor ConnectorUSB ConnectorHost: USB-AOTG: USB-MiniABFunction: USB-MiniBRS232 Serial Connector9-pin DSUBLCD Display Connector14-pin socketLCD Panel Connector2.54 mm pitch, 50-pin (TFT)Application Board Interface2.54 mm pitch, 26-pin x 2 (JA1, JA2), 24-pin x 2 (JA5, JA6)BUS Interface Option2.54 mm pitch, 50-pin (JA3)* USB Power Jack, E20 Connector, USB Connector (USB-MiniB), LCD Panel Connector, Application Board Interface and BUS Interface Option are not contained in the product.* The potentiometer is fitted to offer an easy way of supplying a variable analog input to the controller. It does not necessarily reflect the accuracy of the controllers ADC. Please see the device manual for details.Manufacturer Name: PIHER INTERNATIONAL CORPORATIONPart Number: N6R (6 mm RoHS reflowable potentiometer) Configuration
  • CPU Board
  • Detachable LCD Display Module
  • Detachable AD Adjustment Shaft
  • E1 Emulator
  • Connection Cable (USB Cable, User Interface Cable)
  • Multi region 12 V power supply
  • Quick Start Guide
  • CD-ROM- Documents: User Manual, Tutorial, and more- IDE: High-performance Embedded Workshop- C Compiler: C/C++ Compiler Package for RX Family Evaluation Version- Debugger: E1/E20 Emulator Debugger
Notes
  • The C/C++ Compiler Package for RX Family Evaluation Version does not come with technical support services. In addition, The C/C++ Compiler Package for RX Family Evaluation Version has some restrictions compared to the Product Version.Trial period: 60 daysThe link size will be limited to 128 KB after 60 days.
PC System Requirements
  • IBM PC/AT or compatible PC (USB interface necessary) *1
  • Intel Pentium Ⅲ 600 MHz or higher *3
  • Memory 128 MB or higher
  • Microsoft Windows 7 / Windows XP / Windows Vista *2
下载连接:
RX62N 入门套件用户指南
RX62N 入门套件指导手册
RX62N 入门套件快速入门指南
GMT+8, 2024-11-26 23:46 , Processed in 0.112609 second(s), 15 queries , MemCache On.
