查看: 253|回复: 0
CY3210-PSoCEval1
发表于 2012-8-29 17:16:23 | 显示全部楼层 |阅读模式
CY3210 PSoC评估套件用于PSoC 1 处理器片上系统设计方法和结构的实验和评估。This PSoC Evaluation Kit features an evaluation board and MiniProg programming unit. The evaluation board includes an LCD module, Potentiometer, LEDs, and plenty of breadboarding space to meet all of your evaluation needs. The MiniProg programming unit is also included with the kit and will program PSoC devices directly on the evaluation board, or on other boards via a 5-pin header.  This programming unit is small and compact, and connects to a PC via a provided USB 2.0 Cable.Kit Includes:
  • Evaluation Board with LCD Module
  • MiniProg Programming Unit
  • PSoC Designer Software CD
  • 28 Pin CY8C29466-24PXI PDIP PSoC Device Sample
  • 28-pin CY8C27443-24PXI PDIP PSoC Device Sample
  • USB 2.0 Cable
  • Getting Started Guide
Hardware DescriptionSupports all PSoC Mixed-Signal Array families, including automotive, except CY8C25/26xxx devices.
CY3210-PSoCEVAL1 Kit 用户指南.pdf
4.3 MB, 下载次数: 0
CY3210-PSoCEVAL1 Kit 快速入门指南.pdf
676.1 KB, 下载次数: 0
GMT+8, 2024-11-27 00:24 , Processed in 0.118787 second(s), 16 queries , MemCache On.
