查看: 334|回复: 0
CY8CKIT-020 PSoC CY8C28 系列处理器模块套件
发表于 2012-8-29 16:27:05 | 显示全部楼层 |阅读模式
PSoC CY8C28系列处理器模块套件用于PSoC 1 处理器片上系统设计方法和结构的实验和评估。This processor module can be used in conjunction with the PSoC Development Kit (CY8CKIT-001) to create designs utilizing on-board DVK resources or compatible expansion boards. This kit provides you with an additional processor module to use with different projects.Kit Content:
  • PSoC CY8C28 Family Processor Module
  • Printed Documentation
    • Quick Start
    • Schematic PSoC Development Board Design
  • Software CD for PSoC 1, which includes
    • PSoC® Designer™ IDE
    • PSoC® Programmer™ Software
    • CY8C28 Data Sheets
    • Example Project Files, Firmware, and Documentation
Hardware Description:The PSoC® CY8C28 Family Processor Module is designed to evaluate and experiment with Cypress’s PSoC 1 programmable system-on-chip design methodology and architecture. This processor module can be used in conjunction with the PSoC Development Kit (CY8CKIT-001) to create designs utilizing on-board DVK resources or compatible expansion boards. This kit provides you with an additional processor module to use with different projects.
GMT+8, 2024-11-27 00:21 , Processed in 0.114430 second(s), 15 queries , MemCache On.
