TA的每日心情 | 开心 2013-9-2 09:06 |
签到天数: 11 天 连续签到: 1 天 [LV.3]偶尔看看II
单片机型号: XC2361E-136F128L封装: LQFP-100CPU时钟频率: 128 MHz片上存储:90 kByte SRAM,1088 kByte FLASHUSB连接线用于:- Power supply- Virtual COM Port- Download & Debug Interface组成:- Easy Kit Hardware- Getting Started, first 3 Steps to setup you Hardware, install the Tools and Debug the first Program- Technical Documentation: e.g. User manuals (System unit and Peripheral unit), Architecture manual, Application notes, Errata sheets, Data Sheets, Board Documentation (pdf-version),- Evaluation Versions of Development Tools: e.g. Compiler, Debugger, DAvE Mother System v2.1 and Derivative Implementation Files (DIP), Memtool (Flash Programming Tool),- Training Documentation, Demo Programs, Hands On Training (HOT),接口:- One USB connector for ASC0 Interface via virtual COM port, JTAG (OCDS Level 1) and Power Supply- 4 pin header for LIN Transceiver (ASC1)- 16-pin header for JTAG interface (OCDS)- 2x 10pin (2x5) Header for CAN High Speed Transceiver (CAN1/CAN2)- Easy access to all pins组件:- FTDI2232D for Serial and JTAG connection, plus Power Supply 5V- Two LEDs to validate the USB enumerate State and Debug RUN state- Optional selectable Step down Voltage Regulator TLE6365G to supply 5V- LEDs to validate power supply (5Volt)- LED indicating /RSTIN active state- 2 x CAN-Transceiver TLE 6250G- AT25128N SPI EEPROM- LIN Transceiver TLE 7259G- 8 general purpose LEDs- Reset switch |
