M3A-HS71 是CPU开发板,装有SH7670 (SH-2A core, operating at 200MHz, 256-pin version).Notice | Power supply and development tool are not included in this product. Following items should be prepared by user before using this CPU board.- 5V DC Power supply (1.5A min.)- SuperH RISC engine C/C++ compiler package- E10A-USB emulator | Product Information
CPUPart numberOperating voltageCPU mountingSDRAMEEPROMFLASH ROMSH7670M3A-HS71G50I/O: 3.3V DCInternal: 1.2V DCMounted on board directlyImplementedImplementedImplemented
Features
| M3A-HS71 is a CPU board equipped with SH7670 (SH-2A core, operating at 200MHz, 256-pin version). | | Comes standard with USB and LAN connectors. | | Comes standard with MPEG transport stream interface (STIF) connector, MIL-STD. | | Easy for evaluation of on-chip peripheral I/O s and system extension | | All SH7670 I/O ports are connected to extension connector s (*1) to enable to develop the extension board for variety of use. | | H-UDI connector (14-pin), which can be connected with E10A-USB (*2) is mounted on board. | | *1:Connectors except USB, LAN and STIF are through-hole.*2: Optional item | Specifications
ItemSpecificationEthernet
- RJ-45 LAN connector built-in pulse transformer (8-pin, RJ-45)
- Implements PHY-LSI RTL8201CP-VD-LF of Realtek
USB
- USB connector: Comes with A-type socket
- VBUS power controlled
Connectors /through-hole
- H-UDI connector (14-pin)
- Serial port connector (RS-232C, 9-pin, D-sub)
- 20-pin MIL-STD connectorSH7670 extension connector: 4pcs, SH7670 STIF connector: 2pcs
- 40-pin MIL-STD connectorSH7670 extension connector: 2pcs
LED
- Power LED (1 pc.)
- User LED (4pcs.)
- Ethernet communication status LED (5pcs.)
Switch
- Reset switch, NMI switch, IRQ0 switch, test switch
- DIP switch for DIP mode setting (1pc, 5 poles)
- User DIP switch (1pc, 4poles)
- PHY controller operation mode switch (1pc, 6poles)
Dimensions
- Dimensions: 145mm x 150mm (Projection not included)
- CPU mounting: 4-layer, double-side mounted
- Board configuration: 1 board
Accessories
- CD-ROM- User’s Manual (Circuit diagram included)- Installation Manual- Sample program (setting example of bus controller, Ethernet sample program, USB sample program et al.)
- Release Note
- Power cableNote: Following items should be prepared by user. (Not included in this product)- 5V DC power supply (1.5A min.)- SuperH RISC engine C/C++ compiler package- E10A-USB emulator
Product Appearance
Top view of component sideTop view of solder side
下载连接:
M3A-HS71用户指南 |
