CY3273低压电线通讯评估套件证明了CY8CPLC10器件的能力,在低压(12-24V AC/DC) 电源线上传输数据达到 2400 bps。 Features:
- Chip power supply derived from 12V to 24V AC/DC
- On-chip powerline bridge application layer, powerline network protocol layer, and physical layer FSK modem
- LED status indicators for Power, Powerline Transmit and Receive, and Band in Use
- Five-position DIP switches
- Three DIP switches for node logical address selection
- One DIP switch to configure node I2C addressing mode
- One DIP switch to select between the external crystal and oscillator
- Integrated Powerline Modem PHY
Kit Contents:
- CY3273 Quick Start Guide
- CY3273 PLC LV Evaluation Board
- CD containing:
- CY8CPLC10 Data Sheet
- Packet Test Software – PLC Control Panel Application
- CY3273 Evaluation Board User Guide
- Application Note – Using CY8CPLC10 in Powerline Communication (PLC) Applications
- CY3273 Board Schematics
- CY3273 Board Gerbers
- 12V Power Supply
- Cable to Create LV Daisy Chain
- USB-I2C Bridge
- Five Wire Ribbon Cable for I2C communication, External Reset, and Powering External Board
- Retractable USB Cable
- Five CY8CPLC10-28PVXI Device Samples
