查看: 619|回复: 0
TC1728入门套件
  • 签到天数: 11 天
    发表于 2012-8-27 16:05:31 | 显示全部楼层 |阅读模式
    TC1728入门套件让您更简单的了解和开发TriCore应用。MCU Derivates: SAK-TC1728-192F133HLCPU Clock: 133 MHzIncluding:- TriBoard Hardware- USB cable- Power Supply- Extension Board- Free TriCore Entry Tool Chain- Getting Started, first 3 Steps to- Install the Tools- Set up your Hardware- Write and debug your first ProgramOn-Chip Memory:- 1,5 MByte embedded program flash with ECC- 64 KByte data Flash- 152 KByte on-chip SRAM,- 4 KByte data cache (configurable)- 8 KByte instruction cache (configurable)Interfaces:– One USB connector for ASC0 Interface via virtual COM port, JTAG (OCDS Level1)– 16-pin header for JTAG interface (OCDS Level 1)– 10-pin header for DAB– 2 x 10pin (2x5) header for CAN High Speed Transceiver (CAN0 and CAN1)– 2 x SUB-D9 Plug connector for FlexRay– Four 80-pin connectors (male) + four 80-pin connectors (female) with all I/O signals– ETK connector (optional)Components:– Infineon’s Next generation micro controller supply TLE 7368 G– 2 x Infineon’s High Speed CAN-Transceiver TLE 6250 GV33– USB to UART bridge FT2232D (FTDI)– SPI EEPROM (Atmel)– 2 x FlexRay Transceiver AS2821(AMS) or TJA1080 (NXP)– Three LEDs to validate power supply (5Volt / 3,3 Volt / 1,5 Volt)– LED indicating /HDRST (ESR0) active state– LED indicating active miniWiggler– LED switched via DAS software– 8 general purpose LEDs– Reset switch– 8-pin Dip switch (Hardware Boot Configuration)
    下载连接:
    TC1728入门套件用户指南
    GMT+8, 2024-11-27 02:31 , Processed in 0.108715 second(s), 15 queries , MemCache On.
