CY8CKIT-031 PSoC CapSense 扩展板套件可以让你用 PSoC 3和 PSoC 5器件开发CapSense解决方案。This kit is designed for use with the CY8CKIT-001 PSoC Development Kit (sold separately), CY8CKIT-030 PSoC 3 Development Kit (sold separately) and CY8CKIT-050 PSoC 5 Development Kit (sold separately). The new PSoC® 3 and PSoC 5 architectures enable CapSense on all devices and the CapSense signals can be routed to any of the GPIO pins (up to 62). Due to the vast amount of programmable analog and digital resources available in these devices, as well as the higher performance CPUs and larger memory sizes, PSoC® 3 and PSoC 5 make great single chip solutions. Typically these applications have a microcontroller doing various functions and a separate CapSense solution. PSoC® 3 and PSoC 5 enable integration of these two devices into a single chip solution. What's more, PSoC® 3 and PSoC 5 CapSense leverages the revolutionary SmartSense™ auto tuning solution. Cypress's SmartSense solution is the industry's first and only true self-tuning system. This patent-pending solution optimizes parameters automatically during the design process, significantly reducing development time, while providing the most robust and quality CapSense solution on the market.Kit Contents
The CY8CKIT-031 PSoC CapSense Expansion Board Kit includes:
- CY8CKIT-031 PSoC CapSense Expansion Board
- CY3280-BMM Universal CapSense Matrix Button Module Kit
- CY3280-SLM Universal CapSense Linear Slider Module Kit
- Two 1.5 mm overlay and one 3 mm overlay
- Quick Start Guide
- Resource CD
