查看: 318|回复: 0
CY8CKIT-016 PSoC 1热管理套件
发表于 2012-8-27 10:54:52 | 显示全部楼层 |阅读模式
看你怎样在一个低成本的PSoC 1器件上集成热管理功能
  • 闭环4线风扇控制
  • 温度测量
  • 根据温度测量风扇转速控制
  • 显示
Easy to use Modular Design
The CY8CKIT-001 PSoC 1 Development Kit allows you to evaluate Cypress's PSoC 1, PSoC 3 and PSoC 5 families. The modular design allows you to interface with different types of Expansion Board Kits. In this case the CY8CKIT-036 plugs onto the CY8CKIT-001, which uses the firmware example project of the CY8CKIT-016 to demonstrate Thermal Management functions.Example Project Description
Example firmware provides a quick demonstration of a two-zone Thermal Management system. Zone 1 consists of a 4-wire fan, the I2C temperature sensor and a potentiometer that simulates a diode. Zone 2 consists of the other 4-wire fan, a PWM output temperature sensor and a 1-wire temperature sensor. Fan RPM is controlled based on the weighted average readings of temperature sensors in their zones. Fan RPM zone temperature readings and fan faults are displayed in LCD.
PSoC One-chip Solution
This Thermal Management solution is used by Tier 1 Customers in Data and Telecom equipment. It can be your solution as well. Options include:
  • Driving up to 8 fans in closed-loop or open-loop
  • Interfacing with Multiple Digital and Analog Sensors
  • Communicating via I2C, SPI, UART or PMBus* and SMBus*
Kit Contents
System CD ISO containing:User’s GuidePSoC Designer™PSoC ProgrammerExample ProjectApplication Notes
CY8CKIT-016 用户指南.pdf
2.31 MB, 下载次数: 0
CY8CKIT-016 快速入门指南.pdf
1.55 MB, 下载次数: 0
GMT+8, 2024-11-27 02:22 , Processed in 0.110487 second(s), 16 queries , MemCache On.
