查看: 325|回复: 0
XMC4500 通用CPU电路板
  • 签到天数: 11 天
    发表于 2012-8-27 10:55:40 | 显示全部楼层 |阅读模式
    CPU电路板CPU_45A-V2是XMC4500微控制器和三个连接器(HMI, COM, ACT)的应用扩展板。The board along with satellite cards (e.g. HMI_OLED-V1, COM_ETH-V1, AUT_ISO-V1 boards) demonstrates the capabilities of XMC4500. The main use case for this board is to demonstrate the generic features of XMC4500 device including tool chain. The focus is safe operation under evaluation conditions. The board is neither cost nor size optimized and does not serve as a reference design.MCU Derivate: XMC4500-F144K1024MCU Package: LQFP144CPU Clock: 120 MHzOn-Chip Memory:1024 kByteFlash160 kByte SRAMInterfaces:- USB Connector (Micro-AB USB)- Cortex Debug+ETM Connector (20-pin)- Cortex Debug Connector (10-pin)- DriveMonitor2 Connector (10-pin + 6-pin)- HMI Satellite Connector (80-pin edge card)- COM Satellite Connector (80-pin edge card)- ACT Satellite Connector (80-pin edge card)- Power Scale Connector (for power measurement)Components:- Infineon’s Linear 3.3V Power Regulator IFX1763- Serial Flash Memory, 32 MBit, single/double/quad SPI- LED for general purpose use (connected to P3.9)- Potentiometer for ADC (connected to P14.1)- 12 MHz crystal and 32.768 kHz crystal- Reset button- 2-pin DIP switch (Hardware boot mode selection)- LED indicating active PORST (Reset) signal- 3 LEDs indication power (3.3 Volt, 5 Volt, 5 Volt USB)
    下载连接:
    六角应用开发包用户指南
    XMC4500通用CPU电路板电路图.zip
    408.4 KB, 下载次数: 2
    GMT+8, 2024-11-27 02:41 , Processed in 0.112525 second(s), 16 queries , MemCache On.
