TA的每日心情 | 开心 2013-9-2 09:06 |
签到天数: 11 天 连续签到: 1 天 [LV.3]偶尔看看II
DEMO9S12HY64是针对MC9S12HY64微控制器设计的演示板。Application development is quick and easy with the integrated USB-BDM, sample software tools, and examples. An optional BDM_PORT port is also provided to allow use of a BDM_PORT cable. A 40-pin connector provides access to most IO signals on the target MCU.
特性:
- MC9S12HY64, 100 LQFP
- 64K Bytes Flash
- 4K Bytes Data Flash
- 4K Bytes RAM
- Integrated 4x40 LCD Driver
- Integrated 8-Ch Stepper Motor Controller
- 32MHz Maximum Bus Frequency
- Internal Oscillator
- On-Board 4x40 Custom LCD Glass
- High-Speed CAN Physical Layer Transceiver
- Enhanced LIN Physical Layer Transceiver
- RS-232 Serial Data Physical Layer Transceiver
- Integrated P&E USB-BDM
- BDM_PORT header for external BDM cable support
- MCU_PORT pin header for access to MCU IO signals
- On-board +5V regulator
- Optional Power from USB-BDM or MCU_PORT connector
- Power Input Selection Jumpers
- Power input from USB-BDM
- Power input from on-board regulator
- Power input from Connector J1
- Optional Power output through Connector J1
- User Components Provided
- 5 Push Switches; 4 User, 1 Reset
- 6 LED Indicators; 4 User, +5V, USB
- 5K ohm POT w /LP Filter
- User Option Jumpers to disconnect Peripherals Connectors
- 40-pin MCU I/O Pin Header
- 2.0mm Barrel Connector
- BDM_PORT Connector for External BDM Cable
- USB Connector
- DB9 Connector
- 4.2mm, 1x4 Molex CAN Cable Connector
- 4.2mm, 2x2 Molex LIN Cable Connector
