查看: 403|回复: 0
16位MC9S12XF512评估板
  • 签到天数: 11 天
    发表于 2012-8-24 13:57:39 | 显示全部楼层 |阅读模式
    EVB9S12XF512E是一个为MC9S12XF512 微控制器随时准备使用充满特色的评估系统,包含 XGATE协处理器的16 位单片机、 512 KB 闪存和 FlexRay ™ 嵌入式控制器。
    The EVB9S12XF512 Evaluation Board takes advantage of the CodeWarrior® tool suite and Freescale USB-BDM interface to help make your development process simple and quick.You can enter inputs through the use of two pushbuttons and receive feedback from eight LEDs. These pushbuttons can be disabled by jumpers for using MCU pins for other applications. The board has all of the MCU pins mirrored on pin header connectors which allow you to have extended development flexibility. The control signals going to the FlexRay transceivers can also be disconnected for further expansion of the capabilities of the board. An application example is included to test the features of the board.
    特性:
    • 1 x S12XF512MLM MCU
    • 2 x NXP TJA1080 FlexRay transceiver
    • 1 x Freescale MC33742 system basic chip for hi-speed CAN communication
    • Selectable 4 MHz oscillator module (socketed) or a 4 MHz crystal
    • BDM connector for external in-circuit debugging
    • Header connectors with all microcontroller signals
    • One CAN connector with transceiver integrated in the MC33742
    • Two FlexRay connectors with two transceivers
    • Eight user LEDs
    • Two push-buttons
    • Reset push-button for the MCU and/or the SBC
    下载连接:
    16位MC9S12XF512评估板用户指南
    GMT+8, 2024-11-27 02:33 , Processed in 0.106158 second(s), 15 queries , MemCache On.
