查看: 355|回复: 0
MPC5604E 评估板
发表于 2012-8-24 13:37:28 | 显示全部楼层 |阅读模式
MPC5604E EVB是用于汽车安全和底盘控制应用。  该评估套件包含P&E调试器和所有电源线。
Features
  • A 12VDC power supply input barrel connector
  • Standard 14-pin ONCE JTAG debug connector
  • Video Encoder Wrapper connected to Omnivision connector supporting Omnivision camera evaluation boards
  • Serial Audio Interface connected to the Audio connector supporting Freescale Sahara SGTL5000 daughter card
  • Onboard ethernet physical interface + MII lite connector
  • FlexCAN channel routed to the prototyping area with DB9 connectors to allow additions CAN physical interface to be easily integrated
  • LINFLEX Molex Connector and 0.1" 4pin header are available
Kit Contains
  • MPC5604EEVB Board
  • P&E Debugger and all power supply cables
  • 10 Shunts
  • 20 zero ohms resistors for future reconfiguration
  • CD: P&E Power Architecture® NEXUS driver and resource CD
  • Documentation
  • Freescale Warranty Card
下载连接:
MPC5604EEVB64 评估板用户手册
GMT+8, 2024-11-27 02:44 , Processed in 0.107647 second(s), 15 queries , MemCache On.
