查看: 372|回复: 0
9S12XHY256演示板
  • 签到天数: 11 天
    发表于 2012-8-24 13:25:37 | 显示全部楼层 |阅读模式
    DEMO9S12XHY256是针对 MC9S12XHY256 MCU的演示板。Application development is quick and easy with the integrated USB-BDM, sample software tools, and examples. An optional BDM_PORT port is also provided to allow use of a BDM_PORT cable. A 40-pin connector provides access to most IO signals on the target MCU.
    Features
    • On-Board 4x40 Custom LCD Glass
    • 2 ea. High-Speed CAN Physical Layer Transceivers
    • Enhanced LIN Physical Layer Transceiver
    • RS-232 Serial Data Physical Layer Transceiver
    • Integrated USB-BDM. BDM_PORT header for external BDM cable support
    • MCU_PORT pin header for access to MCU IO signals
    • On-board +5V regulator
    • Optional Power from USB-BDM or MCU_PORT connector
    • Power Input Selection Jumpers, select from USB-BDM, on-board regulator, Connector J1. Optional Power output through Connector J1
    • User Components Provided, including 5 Push Switches, 6 LED Indicators, 5K ohm POT w /LP Filter
    • User Option Jumpers to disconnect Peripherals
    • Connectors, including 40-pin MCU I/O Pin Header, Barrel Connector, BDM_PORT Connector for External BDM Cable, USB/DB9/CAN cable/LIN cable Connector
    下载连接:
    9S12XHY256演示板用户指南
    GMT+8, 2024-11-27 02:19 , Processed in 0.111116 second(s), 15 queries , MemCache On.
