查看: 283|回复: 0
MM912F634单片机评估工具包
  • 签到天数: 11 天
    发表于 2012-8-24 11:44:20 | 显示全部楼层 |阅读模式
    KIT912F634EVME评估工具支持MM912F634,此评估工具集成了一个HCS12单片机 SMARTMOS 模拟控制IC(系统基础芯片),是新的内部高性能模到模交互界面 (D2D)的集成单个产品包解决方案。The D2D controlled analog die combines system base chip and application specific functions, including a Local Interconnect Network (LIN) transceiver.The D2D-Interface realizes the advantage of a seamless MCU register map, integrating the analog die registers, while providing faster access than SPI based systems.
    Features
    • 16-Bit S12 CPU, 32 kByte FLASH, 2 kByte RAM
    • Background debug (BDM) & debug module (DBG)
    • Die to Die bus interface for transparent memory mapping
    • On-chip oscillator & two independent watchdogs
    • LIN 2.1 Physical Layer Interface with integrated SCI
    • 6 digital MCU GPIOs shared with SPI (PA5…0)
    • 10-Bit, 15 Channel - Analog to Digital Converter (ADC)
    • 16-Bit, 4 Channel - Timer Module (TIM16B4C)
    • 8-Bit, 2 Channel - Pulse width modulation module (PWM)
    • Six high voltage / Wake-up inputs (L5…0)
    • Three low voltage GPIOs (PB2…0)
    • Low power modes with cyclic sense & forced wake-up
    • Current sense module with selectable gain
    • Reverse battery protected voltage sense module
    • Two protected low side outputs to drive inductive loads
    • Two protected high side outputs
    • Chip temperature sensor
    • Hall sensor supply & integrated voltage regulator(s)
    下载连接:
    MM912F634评估工具用户指南
    GMT+8, 2024-11-27 02:18 , Processed in 0.104499 second(s), 15 queries , MemCache On.
