XPC560P EVB是MPC560xP 微处理器的评估系统。The complete system consists of an XPC56xxMB Motherboard and an XDC560P Mini-Module which plugs into the motherboard. Different Mini-Modules are available for evaluating devices with different footprints in the MPC560xP family of microprocessors. The evaluation system allows full access to the CPU, all of the CPU’s I/O signals, and the motherboard peripheralsThe Mini-Module may be used as a stand-alone unit, which allows access to the CPU, but no access to the I/O pins or any motherboard peripherals.
Features
XDC560P Mini-Module Board Features
- Can be used as a stand-alone board by providing external 5V power supply input
- XDC560P100S has socket for MPC560xP in 100LQFP footprint
- XDC560P144S has socket for MPC560xP in 144LQFP footprint
- XDC560P64S has socket for MPC560xP in 64LQFP
- ON/OFF Power Switch with LED indicator
- Reset button with filter and LED indicator
XPC56xxMB Board Features
- A 12VDC power supply input barrel connector
- 2 CAN channels with jumper enables
- One channel with High-Speed transceiver
- One channel with Low-Speed Fault Tolerant and High-Speed transceiver (selectable with jumpers)
- 2 LIN channels with jumper enables
- One with transceiver and pin header connector populated
- One channel with footprints only
- 1 SCI channel with jumper enables
- 2 FlexRay channels with jumper enables
- One channel with transceiver and DB9 male connector
- One channel with footprint only
- 4 user push buttons with jumper enables and polarity selection
- 4 user LED’s with jumper enables
- 1 potentiometer for analog voltage input
Kit Contains
- XPC56xxMB Motherboard
- XDC560P100SSCH512K or XDC560P64SSCH256K Mini-Module
- XPC56xx Resources CD-ROM
- P&E USB-ML-PPCNEXUS Hardware Interface Cable
- USB A-to-B Cable
- Freescale Warranty Card
下载连接:
XKT560PEVBUM 用户手册 |
