TA的每日心情 | 开心 2013-9-2 09:06 |
签到天数: 11 天 连续签到: 1 天 [LV.3]偶尔看看II
DEMO9S12XSFAME演示板是MC9S12XS128微控制器的功能和应用评估系统。DEMO9S12XSFAME takes advantage of CodeWarriorTM (which groups an editor, assembler, c compiler and debugger) and Freescale USB-BDM interface, that allows the download and debug of the user application in the microcontroller's FLASH memory.Write Code, Download, Evaluate. Yes, that simple!
Features
MC9S12XS128 microcontroller (in 112-Pin LQFP package, already programmed with a demo application).Two clock sources: A 4 MHz crystal; A provision for an external clock module.12 V DC power supply input connector.Power input selection jumper for selecting the input voltage source: 12 V DC input connector; USB connector.A built-in USB-to-BDM circuitry which allows the host PC to communicate with the microcontroller through a standard USB interface. USB 2.0 is fully supported. When using an external in-circuit debugger (via the “BDM” connector), the USB-to-BDM circuitry must be bypassed by removing the BKGD and RESET jumpers.A Reset push-button connected to the MCU Reset pin.A series of inputs: Two push-buttons, together with jumpers to connect/disconnect them to/from the microcontroller.Four DIP-switches, together with jumpers to connect/disconnect them to/from the microcontroller; A potentiometer, together with a jumper to connect/disconnect it to/from the microcontroller.A photocell, together with a jumper to connect/disconnect it to/from the microcontroller.Four high-efficiency (low-current) LEDs together with jumpers to connect/disconnect them to/from the microcontroller.An RS-232 channel connected to the microcontroller’s SCI serial communication interface; Two LIN connectors sharing one LIN transceiver, together with jumpers for configuration; One CAN connector with high-speed CAN transceiver, together with jumpers for configuration. |
