查看: 212|回复: 0
MPC560xB评估板
发表于 2012-8-23 17:10:15 | 显示全部楼层 |阅读模式
XPC560B 评估板是飞思卡尔 MPC560xB MPU的评估系统。The complete system consists of an XPC56xxMB motherboard and an adapter card that plugs into the motherboard. Different adapter cards are available for evaluating various packages in the MPC560xB family of MPUs. The evaluation system allows full access to the CPU, all of the CPU’s I/O signals, and the motherboard peripherals.Features
  • XPC563BADPT Mini-Module Board Features
    • Can be used as a stand-alone board by providing external 5-volt power supply input
    • XDC560B208SC512K has socket for MPC560xB in 208MAPBGA footprint
    • XDC560B144SC512K has socket for MPC560xB in 144LQFP footprint
    • XDC560B100SC512K has socket for MPC560xB in 100LQFP footprint
    • XDC560B176SB15M has socket for MPC560xB in 176LQFP footprint
    • XDC560B144SB15M has socket for MPC560xB in 144LQFP footprint
    • XDC560B100SB15M has socket for MPC560xB in 100LQFP footprint
    • XDC560B208SB15M has socket for MPC560xB in 208MAPBGA footprint
    • ON/OFF Power Switch with LED indicator
    • Reset button with filter and LED indicator
  • XPC56xxMB Board Features
      • 12 V DC power supply input barrel connector
      • 2 CAN channels with jumper enables
        • One channel with high-speed transceiver
        • One channel with low-speed fault tolerant and high-speed transceiver (selectable with jumpers)
      • 2 LIN channels with jumper enables
        • One with transceiver and pin header connector populated
        • One channel with footprints only
      • 1 SCI channel with jumper enables
      • 2 FlexRay™ channels with jumper enables
        • One channel with transceiver and DB9 male connector
        • One channel with footprint only
      • 4 user push buttons with jumper enables and polarity selection
      • 4 user LEDs with jumper enables
      • 1 potentiometer for analog voltage input
Kit Contains
  • XPC56xxMB motherboard
  • One of the following adapter cards
    • XDC560B208SC512K
    • XDC560B144SC512K
    • XDC560B100SC512K
    • XDC560B176SB15M
    • XDC560B144SB15M
    • XDC560B100SB15M
    • XDC560B208SB15M
  • XPC56xx Resources CD-ROM
  • P&E USB-ML-PPCNEXUS Hardware Interface Cable
  • USB A-to-B Cable
  • Freescale Warranty Card
下载连接:
XPC560BEVB 用户指南
GMT+8, 2024-11-27 03:47 , Processed in 0.119101 second(s), 15 queries , MemCache On.
