查看: 353|回复: 0
KIT33812ECUEVME评估板
  • 签到天数: 11 天
    发表于 2012-8-23 16:50:57 | 显示全部楼层 |阅读模式
    KIT33812ECUEVME评估板是为评估飞思卡尔9S12P128 MCU特性而设计的。This Reference Design is a fully functional Single Cylinder Engine Control unit (ECU). This engine control module features the Freescale 33812 and a 9S12P128 MCU device. The 33812 is an analog power IC intended for motorcycle and other single/dual cylinder small engine control applications. The 9S12P128 MCU provides a cost effective 16 bit microcontroller solution.
    特性:
    • Designed to operate over the range of ~4.9 V ≤ VPWR ≤ 18 V
    • MC9S12P128 has 128K bytes of Flash memory w/ECC, 6 K bytes of RAM, 4 K bytes of Data Flash w/ECC, 12-bit ADC, USB base BDM tool
    • MCU is coded to perform the complete engine control functionality
    • MCU can be recoded for parameter tables and engine customization
    • ECU S/W fully supports the reference design H/W
    • Monitors & controls all required inputs and outputs for a single/dual cylinder ECU (incl. O2 heater, Throttle motor, MAP, TPS, VRS, TEMP, TILT)
    • Fuel Injector driver - Current Limit - 4.0 A Typical
    • Relay driver - Current Limit - 4.0 A Typical (fuel pump, vehicle battery supply)
    • Lamp driver- Current Limit - 1.5 A Typical (check engine light)
    • ISO-9141 K-Line transceiver for communicating diagnostic messages
    • The reference design can easily migrate to the S12XS or S12XE MCU families
    下载连接:
    KIT912H634EVME评估板用户指南
    GMT+8, 2024-11-27 03:52 , Processed in 0.120010 second(s), 15 queries , MemCache On.
