查看: 271|回复: 0
MCF5253成本更低的演示板
发表于 2012-8-23 16:41:53 | 显示全部楼层 |阅读模式
M5253DEMO是一个基于 MCF5253 CodeFire处理器的成本更低的多功能演示版。This board is designed as a validation platform with the maximum flexibility. It serves as a complete microcomputer system for reference design, development/evaluation, training, and educational use. Further more, the board also includes ethernet controller on the system flexbus for debugging and developping purpose.
Features
The following is a list of demo board features.MCF5253 External Interfaces:
  • Synchronous Serial Interface (SSI) connected to audio codec WM8731
  • USB Support
    • Standalone USB host controller, support enhanced host controller interface(EHCI)
    • USB device mode
    • USB On-The-Go mode including host capability
    • Supports high-speed(480Mbps), full-speed(12Mbps), and low-speed host(1.5Mbps) operations
    • Supports internal PHY (with UTMI+ interface)
  • Crystal/Clock
  • On board BDM
  • ATA interface
  • MMC/SD interace
  • 2 I2Cs
  • 4 QSPIs
  • 2 CANs
  • 3 UARTs
  • 6 12bit resolution AD
  • Flexbus with 10/100 ethernet controller
  • Timers
  • External Interrupts
Memory Subsystems:
  • 16bit Width SDRAM
  • 2x64 Kbyte SRAM
  • 8k on-chip BootROM
  • FLASH device for Boot Code Development
Power:
  • Inputs:
    • 5V (Input to the voltage regulator circuitry)
  • Regulated On-board voltages:
    • 5V for USB VBUS support
    • 3.3V – I/O Voltage
    • 1.2V – CPU Core Voltage
下载连接:
M53015EVB_QSG 快速入门指南
MC9S12XDP512评估板用户指南
GMT+8, 2024-11-27 03:37 , Processed in 0.111379 second(s), 15 queries , MemCache On.
