TA的每日心情 | 开心 2013-9-2 09:06 |
签到天数: 11 天 连续签到: 1 天 [LV.3]偶尔看看II
TWR-S12G128是为16位MC9S12G128汽车MCU设计的演示板。An integrated open-source BDM, software tools, and examples provided with the development board make application development and debug quick and easy. All MCU signals are available on one or both edge connectors.Write Code, Download, Evaluate. Yes, that simple!The TWR-S12G128 operates as a standalone debug tool and can also be combined and used as part of the modular Tower System development platform.特性:
Push Buttons and LED
- 4 user Push Button Switches
- 4 user LED Indicators
MC9S12G128, 100 LQFP
- 128 KB Flash
- 4096B EEPROM
- 8192B RAM
- 25 MHz Bus Frequency
- Internal oscillator
- SCI, SPI, MSCAN
Transceivers
- 1 ea. high-speed CAN Physical Layer Transceiver
- 1 ea, Enhanced LIN Physical Layer Transceiver
- RS-232 Serial Data Physical Layer Transceiver
Power Input Selection Jumpers
- Power input from USB-BDM
- Power input from on-board regulator
- Power input from Tower System edge connector
5K ohm POT w /LP Filter
- User Option Jumpers to disconnect Peripherals
- Connectors
Connectors and Header
- BDM_PORT Connector for External BDM Cable
- USB mini-AB Connector
- 1x4, 4.2mm, Molex CAN Cable Connector
- 2x2, 4.2mm, Molex LIN Cable Connector
- 2x5, 0.1” ctr, RS-232 Header
Integrated Open Source BDM
- Integrated open-source BDM (OSBDM)
- BDM_PORT header for external BDM cable support
- Power input from OSBDM, Tower System, or input vias at E1/E2
Additional FeaturesOn-board +5V regulator
下载连接:
MC9S12G128S汽车MCU模块用户指南 |
