查看: 320|回复: 0
MC9S12GN32汽车MCU模块
  • 签到天数: 11 天
    发表于 2012-8-23 16:28:12 | 显示全部楼层 |阅读模式
    此演示板是用于16位MC9S12GN32 汽车MCU的。An integrated open-source BDM, software tools, and examples provided with the development board make application development and debug quick and easy. All MCU signals are available on one or both edge connectors. An IO ring around the MCU also provided easy access to all signals.The TWR-S12GN32 operates as a standalone debug tool and can also be combined and used as part of the modular Tower System development platform.特性:
    MC9S12GN32, 48 LQFP
    • 32 KB flash
    • 1024B EEPROM
    • 2048B RAM
    • 25 MHz Bus Frequency
    • Internal oscillator
    • SCI, SPI
    Connectors
    • 2x3 BDM_PORT connector for external BDM cable
    • USB mini-AB connector for OSBDM
    • 2x5, 0.1” ctr, RS-232 header
    Power input Selection Jumpers
    • Power input from integrated OSBDM
    • Power input from on-board regulator
    • Power input from LIN connectors
    • Power input from Tower System edge connector
    Peripherals
    • 5 push-button switches, 4 user, 1 reset
    • 7 LED indicators, 4 user, 2 OSBDM, 1 Power 5K ohm POT w /LP filter
    下载连接:
    MC9S12GN32汽车MCU模块用户指南
    GMT+8, 2024-11-27 03:53 , Processed in 0.113241 second(s), 15 queries , MemCache On.
