查看: 300|回复: 0
MCF5235 商务卡电脑套件
发表于 2012-8-23 16:36:11 | 显示全部楼层 |阅读模式
M5235BCCKIT 提供了完整的低成本模式,用于飞思卡尔 MCF5235 ColdFire 微控制器评估。In addition to the M5235BCC module, the M5235BCCKIT includes a P&E wiggler cable, a CE certified power supply, and associated components needed to run right out of the box.About the size of a business card (3.5 inches x 2.2 inches), the M5235BCC module comes with 2 Mbytes of flash, 16 Mbytes of SDRAM, a 10/100 BaseT Ethernet port, and an award winning ColdFire debug module.  Open source GNU tools and an open source TCP/IP stack is also available along with an available RTOS.  Freescale offers both the M5235BCCKIT and the stand-alone M5235BCC.
Features
  • MCF5235 CPU
  • 2M Byte Flash (16 bit, external)
  • 16M Bytes SDRAM (32 bit, external)
  • Serial ports, DB-9 Connectors
  • 10/100TX Ethernet Port w/ RJ45 Connector
  • 4 status Indicators, Auto MDI-X crossover.
  • Regulated +3.3V and +1.5V power supply w/ indicator
  • Specifications:
    • Board Size 3.5” x 2.2 inches w/ 4 x #2 mounting holes
    • Power Input: +5 - +30VDC, 12VDC typical
    • Current Consumption: 120ma @ 12VDC input typical (100Mhz clock)
下载连接:
M5235BCC硬件用户指南
M5235BCCDS 数据手册
GMT+8, 2024-11-27 04:03 , Processed in 0.109281 second(s), 15 queries , MemCache On.
