查看: 443|回复: 0
HCS12 开发套件
  • 签到天数: 11 天
    发表于 2012-8-23 14:40:35 | 显示全部楼层 |阅读模式
    HCS12开发工具包是是经济的工具,用于开发代码和评价它在HCS12 Dx,A 和 B系列MCU上运行的效果。This easy to order kit combines the Background Debug Mode (BDM) Multilink and an evaluation board (EVB). The EVB simplifies user evaluation of prototype hardware and software by providing the essential MCU timing and I/O circuitry as well as a prototype area to allow custom interfacing. The BDM Multilink interfaces to the EVB through the 6-pin BDM connector for real-time in-circuit emulation and fast flash programming.
    特性:
    • MCS12DP256 Evaluation Board
      • Assembler, assembly level debugger, linker, and programmer
      • 256K Bytes FLASH
      • Prototyping area
      • Header connectors for access to the MCU's I/O and bus lines
      • RS232 Communications
      • CAN Communication
    • BDM Multilink
      • Universal development tool for all BDM 68HC12s and HCS12s
      • Real-time in-circuit emulation and debug
      • Fast in-circuit programming
      • Auto-detects frequency
      • Small unobtrusive size (approx 3" x 2" x 3/4")
      • Supports 2 V to 5.5 V targets
    • Special Edition, HC(S)12 CodeWarrior Integrated Development Environment
      • Debugger, assembler, linker, and flash programming support
      • Evaluation C compiler
    GMT+8, 2024-11-27 03:48 , Processed in 0.109605 second(s), 15 queries , MemCache On.
