查看: 345|回复: 0
MC9S12XDP512评估板
  • 签到天数: 11 天
    发表于 2012-8-23 14:20:40 | 显示全部楼层 |阅读模式
    MC9S12XDP512评估板目的是让设计者开发和评估MC9S12XDP512 MCU的应用。The EVB9S12XDP512 board is packed with useful features that include LEDs, push buttons, two 7x5 dot-matrix displays, light sensor, potentiometer, I/O header, LIN interface, CAN interface, prototype area, and RS-232 COM port.
    Features
    • MC9S12XDP512 CPU, 144 LQFP
      • X-GATE Co-Processor
      • 512 KB Flash EEPROM
      • 4KB EEPROM
      • 32 KB SRAM
      • Enhanced Capture Timer/PWM
      • SCI and SPI Communications Ports
      • Key Wake-up Port
      • Single Wire BDM Interface
      • CAN 2.0 Module
      • Analog to Digital Converter
      • 80 MHz Bus Operation using internal PLL
    • Selectable 16 MHz Oscillator Module (Socketed) or 4MHz Crystal
    • Built-In USB to BDM Interface for In-Circuit Debugging
    •  BDM Connector for External In-Circuit Debugging
    • Header Connectors with All Microcontroller Signals
    • Five CAN Connectors with Transceivers
    • Six LIN Connectors with Transceivers
    • Two RS-232 Connectors with Transceivers
    • FlexRay Expansion Connectors
    • Two 7x5 Dot-Matrix Displays
    • Four User LEDs
    • Potentiometer for Analog Input
    • Light Sensor
    • Four Push-Buttons
    • Reset Supervisor Circuitry with Push-Button
    • Prototype Area
    • RoHS complient version EVB9S12XDP512E
    下载连接:
    MC9S12XDP512评估板用户指南
    GMT+8, 2024-11-27 03:42 , Processed in 0.120808 second(s), 15 queries , MemCache On.
