查看: 299|回复: 0
8位 FL系列演示板
  • 签到天数: 11 天
    发表于 2012-8-23 13:30:30 | 显示全部楼层 |阅读模式
    FL系列演示板配置了使用FL16/8系列微控制器完成整个项目所需要的一切。Application development is quick and easy with the integrated, Open-Source, USB-BDM, sample software tools, and examples. An optional BDM_PORT port is also provided to allow use of a BDM_PORT cable. One, 40-pin connector provides access to all IO signals on the target MCU.
    特性:
    • MC9S08FL16, 32 SDIP with 16K Bytes Flash; 1K Bytes RAM
    • RS-232 Serial Data Physical Layer Transceiver
    • Integrated Open-Source, USB-BDM
    • BDM_PORT header for external BDM cable support
    • MCU_PORT pin header for access to MCU IO signals
    • Three options of power input from: USB-BDM, on-board regulator and Connector J1
    下载连接:
    8位 FL系列演示板用户指南
    8位 FL系列演示板电路图
    GMT+8, 2024-11-27 03:53 , Processed in 0.105263 second(s), 15 queries , MemCache On.
