DEMOQE128是一个低成本开发系统,用于演示、评估和调试飞思卡尔MC9S08QE128 和 MCF51QE128 微控制器。The board supports two interchangeable plug-in daughter cards to quickly evaluate the 8-bit S08 and 32-bit ColdFire V1 QE128 microcontrollers.Embedded Multilink circuitry on the DEMOQE128 board allows the microcontroller on the DEMOQE128 to be powered, programmed, and debugged via USB from the PC. In addition, the demo board contains an on-board logic analyzer and virtual serial port via USB to assist with rapid development.It also supports plug-in RF daughter cards for SMAC and 802.15.4.
Features
- Interchangeable 8-bit S08 and 32-bit ColdFire V1 QE family daughter cards
- P&E's USB Embedded Multilink circuitry eliminates the need for external BDM cable
- Allows for debug, programming, and power to board and device
- SCI signals connected to Multilink through jumpers for on-board virtual serial port
- TPM signals connected to Multilink through jumpers for on-board logic analyzer
- User Features:
- 3-axis Accelerometer w/ Enable
- 8 User LED's w/ Enable
- 4 User Push Buttons w/ Enable
- 1 Piezzo Buzzer w/ Enable
- 1 RS-232 Serial Port w/ DB9-F Connector
- IIC Pullups w/ Enable
- 10K Ohm POT w/ Enable
- Flexible power input sources selectable through jumpers
- USB Cable: 5VDC, 500mA max
- 5VDC to 12VDC Power Jack: 2.5/5.5mm barrel connector, center positive
- 2 AAA Battery Cells
- MCU Port connector
- ON/OFF Power Switch w/ LED indicator
- Selectable regulated VDD Output at 3.0V or 2.1V
- RESET Push Button and LED indicator w/ Enable
- External Crystal Circuitry Layout
- Board Size 3.5 x 4.0''
Kit Contains
- DEMOQE Base Board with a MC9S08QE128 Daughter Card installed
- MCF51QE128 Daughter Card
- DVD-Breaking Bit Boundaries:Getting Started With QE128
- CodeWarrior for Microcontrollers V6.0 – Special Edition
- Device and Board Resources
- Device Training
- 2-cell AAA battery package
- USB Cable
- Quick Start Guide
- Freescale Warranty Card
下载连接:
QE 系列评估板用户手册
QE 系列评估板快速入门指南 |
