查看: 323|回复: 0
MCF5235评估板
发表于 2012-8-23 11:33:49 | 显示全部楼层 |阅读模式
 ColdFire M523xEVB 评估板目的是提供一种途径,使用户能够容易地评估 MCF523x  ColdFire微处理器及进行硬件和软件的开发。   The EVB can be used by software and hardware developers to test programs, tools, or circuits without having to develop a complete microprocessor system themselves.  The heart of the evaluation board is the MCF5235, all other MCF523x family members have a subset of the MCF5235 specification and can therefore be fully emulated using the MCF5235 device.The EVB enables low cost software testing with the use of a ROM resident debug monitor, dBUG, programmed into the external Flash device. Operation allows the user to load code in the on-board RAM, execute applications, set breakpoints, and display or modify registers or memory.  No additional hardware or software is required for basic operation.
Features
  • MCF5235 Microprocessor (150 MHz max core frequency)
  • Memory:
    • 32M byte SDRAM
    • 2M byte external Page Mode Flash
  • Development Ports
    • BDM Debug Development connector
  • General
    • 10/100 Ethernet PHY and RJ45 connector
    • Two CAN transceivers and DB-9 connectors
    • Two serial ports and DB-9 connectors
    • All internal module signal connectors available via four, 60-pin expansion connectors
    • Breakout connector for serial interfaces (eTPU, I2C, QSPI, GPIO)
    • ADC Interface
    • Chip configuration capability
    • Multiple clocking options
    • Debug monitor
    • Power Port with Power Supply Access
    • Power Requirement: 6 to 14V DC input
    • Power output: 5V, 3.3V and 1.5V regulated supplies
下载连接:
入门飞思卡尔开发工具手册
M5235EVB 用户指南
GMT+8, 2024-11-27 03:41 , Processed in 0.108938 second(s), 15 queries , MemCache On.
