EVB51JM128是一个MCF51JM128 ColdFire微控制器的低成本开发系统,是 FLEXIS微控制器连续的一部分。CodeWarrior Development Tools provide support for quick and easy application development and debug.
Features
MCF51JM128 MCU, 80 pins
128K Byte Flash
16K Byte Ram
USB Phy w/ OTG Support
Cryptographic Acceleration Unit
BDM / JTAG Port
USB On-The-Go Support with Mini AB connector
USB FS/LS Support with Type-B connector
ON/OFF Power Switch with LED voltage indicators
User Features
3-Axis MMA7260 Accelerometer
IR Diode
5k ohm POT
Light Sensor
Externally Modulated Buzzer
8 User LED’s
4 User Push Switches
Kit Contains
EVB51JM128 Evaluation board
MCF51JM128 MCU, 80 pins, soldered on the baseboard
