DEMO9S08QE32是一个低成本的开发系统,目的是演示、评估和调试飞思卡尔MC9S08QE32微控制器。P&E’s Embedded Multilink circuitry on the DEMO9S08QE32 board allows the processor to be debugged and programmed via USB from the PC. In addition, the demo board can be powered using the USB bus.
特性:
主板特性:
3-axis Accelerometer w/Enable
8 User LED’s w/ Enable
4 User Push Buttons w/ Enable
1 Piezzo Buzzer w/ Enable
10K Ohm POT w/ Enable
RESET Push Button and LED indicator w/ Enable
RS-232 Serial Port w/ DB9-F Connector
ON/OFF Power Switch w/ LED indicator
Power Options:
USB Cable: 5VDC, 500mA max
DC Power Jack: 2.5/5.5mm barrel connector, 5VDC to 12VDC Center Positive
Two AAA Battery Cells (regulated VDD Output at 3.0V or 2.1V)
P&E’s Embedded Multilink circuitry populated on the bottom
SCI signals connected to P&E’s Embedded Multilink through jumpers
Two channels logic analyzer allows observation of MCU signals
DC9S08QE32子卡特性:
Four bottom-mounted asymmetrically positioned 8x2 female connectors to mate with the DEMOQE Base Board
