查看: 336|回复: 0
SD卡驱动和USB连接的Flexis JM板
发表于 2012-8-23 10:40:31 | 显示全部楼层 |阅读模式
SD卡阅读器参考设计可以让用户通过全速USB模块系统在 SD Card里读写PC或USB主机存储的文件。The SD Card interface is based on SPI protocol. Mass Storage Device class is used to implement the high level communication between the host application and data memory.The SD Card reader reference design shows how easy are to interface a SD Card to an 8 bit microcontroller with a SPI module. This design is an alternative Flexis JM family development board; The user can exchange a MCF51JM128 for a MC9S08JM60 (pin to pin compatible). It includes two user LED’s, one button and one expansion header that allows users to access other microcontroller peripherals like SPI, RGPIO, etc.
Features
  • USB Connectivity
  • Light Sensor
  • SD Card Socket
  • 3 LED (1 power + 2 user leds)
  • 1 push Button
  • Expansion header with access to: SPI, RGPIO, SCI etc
  • 8-32 bit compatible footprint for JM family (S08 included)
Kit Contains
  • PWA, DEMOFLEXISJMSD
  • Technical Information Center Freescale Semiconductor Inc.
  • Warranty Card, Freescale
  • Quick Setup Guide, DEMOFLEXISJMSD
GMT+8, 2024-11-27 03:47 , Processed in 0.113205 second(s), 15 queries , MemCache On.
