DEMO9S08QE8是符合成本效益的快速评估微控制器的开发板。The DEMO9S08QE8 kit includesEMOQE baseboardDC9S08QE8 daughter card.In combination, they can be used to highlight the key features on the MC9S08QE8 device. The board also includes a power terminal to measure the ultra-low power consumption of the MC9S08QE8 device.特性:
主板特性:
3-axis Accelerometer w/ Enable
8 LEDS w/ enable
4 User Push Buttons w/ Enable
1 Piezzo Buzzer w/ Enable
1 RS-232 Serial Port w/ DB9-F Connector
10K Ohm POT w/ Enable
ON/OFF Power Switch w/ LED indicator
RESET Push Button and LED indicator w/ Enable
Power options:
5VDC to 12VDC Power Jack (2.5/5.5mm barrel connector)
USB Cable: 5VDC, 500mA max
2 AAA Battery Cells Selectable (regulated VDD Output at 3.0V or 2.1V)
P&E micro Embedded Multilink USB Connector
USB to SCI communication interface eliminates need for serial COM port on PC
Two channel logic analyzer allows observation of MCU signals
DC9S08QE8 子卡特性:An MC9S08QE8CLC chipFour 8x2 female connectors to mate with DEMOQE8 base board, also compatible with the DEMOQE128 kit.Can be bought separately.Additional interchangeable 8-bit S08 and 32-bit ColdFire V1 QE family daughter cards are available. All daughter cards are compatible in both DEMOQE8 and DEMOQE128 boards.
下载连接: QE8演示板用户指南
