查看: 386|回复: 0
MC908QC16演示板
  • 签到天数: 11 天
    发表于 2012-8-23 09:56:11 | 显示全部楼层 |阅读模式
    DEMO908QC16是MC908QC16微控制器的评估演示板。Development of application code is quick and easy with the integrated USB-to-MON08 interface, CodeWarrior Development Studio, and software examples. A 28-pin connector allows connecting the DEMO908QC16 board to an expanded evaluation environment.
    Features
    • MC68HC908QC16 MCU, 28 SOIC
    • Integrated MON08 Debugger
    • MON08 Header for MON08 Debug cable support (not installed)
      • COM_SEL Jumper Selects Communications Protocol
    • Optional external 8.0 MHz Clock Oscillator w/ enable (not installed)
    • 10-Ch, 10-bit Analog to Digital Converter (ATD) w/ internal bandgap reference
    • Power Input Selection Jumper
      • Power input from USB-MON08 Debugger
      • Power input from on-board regulator
      • Power input from MCU_PORT connector
      • Power output through MCU_PORT connector
    • User Components Provided
      • 3 Push Switches; 2 User, 1 Reset
      • 7 LED Indicators; 4 User, +5V, USB, POWER_OUT
    • Connectors
      • 28-pos MCU I/O Connector
      • 2.0mm Barrel Connector
      • MON08 Pin Header (not installed)
      • RS-232 Serial Port w/ DB9 Connector
      • LIN Bus PHY w/ 2, 4-pin connectors
    下载连接:
    MC908QC16演示板用户指南
    GMT+8, 2024-11-27 03:53 , Processed in 0.117976 second(s), 15 queries , MemCache On.
