查看: 281|回复: 0
MC68HC908JL设计工具包
  • 签到天数: 11 天
    发表于 2012-8-23 09:47:59 | 显示全部楼层 |阅读模式
    inDART-HC08/JL是一个强大的针对飞思卡尔 HC08系统的入门级设计工具套件。It includes an in-circuit debugger/programmer and a derivative-specific evaluation board. inDART-HC08/JL takes advantage of the CodeWarrior Integrated Development Environment (which groups an Editor, Assembler, C Compiler and Debugger) and the Freescale's MON08 interface, which allows the download of the user application into the microcontroller FLASH memory. Together with CodeWarrior, inDART-HC08/JL provides you with everything you need to write, compile, download, in-circuit emulate and debug user code. Full-speed program execution allows you to perform hardware and software testing in real time. inDART-HC08/JL is connected to (and powered by) the host PC through a USB connection.
    特性:
    • Real-Time Code Execution & In-Circuit Debugging
    • Built-In FLASH Programmer
    • In-System Programming and Debugging through a MON08-Compatible Interface
    • CodeWarrior IDE, with Editor, Assembler, C Compiler and Debugger
    • USB Connection to the Host PC
    • Includes inDART-HC08/D + Evaluation Board with a Sample MC68HC908JL Microcontroller
    下载连接:
    MC68HC908JL设计工具包用户指南
    GMT+8, 2024-11-27 03:50 , Processed in 0.107724 second(s), 15 queries , MemCache On.
