M52221DEMO 是一个廉价的飞思卡尔MCF52221 ColdFire 微控制器开发板。
Application development is quick and easy with the included DB9 serial cable, integrated BDM, and USB cable. A 128 MB flash-drive and 6-in-1 USB cable provide support for the integrated USB PHY. CodeWarrior Development Tools provide application develop-ment and debug support. The integrated BDM allows easy application development and de-bugging. An optional BDM port compatible with standard ColdFire BDM/JTAG interface cables and hosting software is also provided but not installed.
The target MCU features an on-board USB On-the-Go (OTG) physical layer (Phy). The OTG Phy may be configured for either Host or Peripheral mode depending on the target application.
Features
- MCF52221 CPU- 80 LQFP- 128 Byte Flash- 16K Byte Ram- USB On-The-Go (OTG) Phy- 4ch, DMA Controller w/ Timers- 2ea. Programmable Interrupt Timer- 4 GPT Timers- 8ch, 12b ADC- UART Serial Ports with DMA capability- QSPI and IIC Ports- 3.3V operation
- Integrated USB BDM
- 48 MHz XTAL
- 40 pin I/O port
- miniUSB Port
- BDM / JTAG Port (not installed)
- RS-232 Serial Port w/ DB9-S Connector
- ON/OFF Power Switch w/ LED indicator
- RESET switch w/ indicator
- Power Input Selection Jumper
- User Features- 3-axis Accelerometer- 4 User LED’s w/ enable- 2 User Push Switches- 5k ohm POT w/ enable
- Option Jumpers
- Connectors- RJ-45 Ethernet Connector- Type B USB connector- DB9 Serial Connector- 2.0mm Barrel Power Input- 2pos, screw type, terminal blockSpecifications:Board Size 3.0” x 4.0”Power Input: +5 to +16 VDC, 9VDC typical
Kit Contains
- MCF5222x CPU 80 LQFP
- 128 MB flash-drive
- Integrated BDM
- M52221DEMO User's Manual
- DB9 Serial Cable
- 6-in-1 USB Cable
- Ethernet Cable
- CodeWarrior Development Studio CD
下载连接:
M5211DEMO 用户指南 |
