查看: 253|回复: 0
MC68HC908LJ/LK入门工具包
  • 签到天数: 11 天
    发表于 2012-8-23 09:35:32 | 显示全部楼层 |阅读模式
    ZK-HC08LX-A入门工具包是一个功能齐全并即时可用z针对飞思卡尔MC68HC908LJ/LK微控制器的产品。A 80-pin Yamaichi QFP ZIF (Zero Insertion Force) socket is provided which allows easy microcontroller insertion/extraction--the Starter Kit can be used as a single programmer. The Starter Kit takes advantage of the CodeWarrior Development Studio Special Edition (which groups an Editor, Assembler, C Compiler and Debugger) and the Freescale MON08 interface, which allows the download and debug of the user application into the microcontroller's FLASH memory. Together with CodeWarrior, the Starter Kit provides you with everything you need to write, compile, download, in-circuit emulate and debug user code. Full-speed program execution allows you to perform hardware and software testing in real time. The Starter Kit is connected to the host PC through a USB port. A prototyping area allows you to wire your own small application.
    特性:
    • Full-Featured Evaluation Board with LCD, RS-232, LEDs, Push-Buttons, DIP-Switches, Potentiometer
    • ZIF Socket for Experimenting with Different Microcontrollers
    • True, Built-In MON08 Debugging through USB Interface
    • CodeWarrior Development Studio Special Edition Included, with Editor, Assembler, C Compiler and Debugger
    下载连接:
    MC68HC908LJ/LK入门工具包用户指南
    GMT+8, 2024-11-27 03:48 , Processed in 0.111220 second(s), 15 queries , MemCache On.
