M54455EVB 平台提供了MCF5445x ColdFire V4m嵌入式微处理器评估系统。The MCF54455 is the superset device in the family and is the processor featured on this platform. This allows evaluation and development for the entire family on a single hardware platform.
Features
- Freescale MCF54455 ColdFire microprocessor
- DDR2 SDRAM (256 MByte)
- Two NOR flash memory devices (16 MByte, 512 KByte)
- Serial flash
- U-Boot bootloader
- MRAM (512 KByte, accessible through FPGA Flexbus interface)
- Four PCI slots
- Two-port Ethernet interface 40-pin
- ATA connector
- Audio interface (I2S mode of SSI module connected to audio codec)
- Multiple USB interface options
- FS/LS Host via on-chip transceiver with host support (Type A receptacle)
- HS/FS/LS dual-role via external ULPI PHY (Mini-AB receptacle)
- Two RS232 serial ports (RS232 transceivers on UART0 & UART1)
- One USB serial port (UART0 serial converted to USB converted on UART0)
- Built-in P&E Micro USB Multilink debug interface
- Standard 26-pin BDM header
- Serial interface header for access to timers, interrupts, DSPI, I2C, and more
- Clock generation logic adjustable via I2C
- LEDs and 7-segment display programmable via CPLD and FPGA
Kit Contains
- Four PCI slots
- ATA connector
下载连接:
M54455EVB用户手册
MCF5445X 快速入门指南 |
