查看: 487|回复: 0
MCF5213 评估板
发表于 2012-8-22 15:31:18 | 显示全部楼层 |阅读模式
轻松搞定演示,支持ColdFire开发,  M5213EVB是廉价的飞思卡尔MCF521x ColdFire 微控制器开发系统。Application development is quick and easy with the included DB9 serial cable and dBUG firmware monitor. The BDM port is compatible with standard ColdFire BDM / JTAG interface cables and hosting software, allowing easy application debugging and development with a variety of hardware and software tools.This cost-efficient evaluation kit offers impressive additions with a fully licensed, complimentary Special Edition of the CodeWarrior Development Studio for ColdFire Architectures  for development of applications up to 128Kbytes code size, as well as a host of ther low cost and professional tools from leading 3rd party tool vendors  The kit also comes equipped with the  MC13192 Zigbee-ready transceiver on board with and integrated Zigbee antenna making the board an impressive low cost ZigBee-enabled reference design.The evaluation board comes fitted with an 80MHz MCF5213 microcontroller (256 Kbyte internal flash). The MCF5213 microcontroller has a superset of the same functional modules and interfaces as those on the other devices supported.See the MCF521X product page for more information on the differences on how to evaluate each microcontroller using the M5213EVB.
Features
  • MCF5213 CPU
  • 256K Byte Flash (on-chip), 32K Byte SRAM (on-chip)
  • Up to 80MHz operation
  • 8MHz reference crystal
  • External clock options
  • MCU port
  • 60 pin I/O port
  • BDM / JTAG Port
  • 26-pin development port
  • UART0 / Terminal Port w/ RS232 DB9-S Connector
  • UART1 Port w/ RS232 DB9-S Connector
  • UART2 / CAN port w/ RS232 and 1Mbaud CAN transceiver
  • RESET switch and indicator
  • 4 User Indicators (LEDs)
  • 2 User Push Switches
  • 2.4GHz Zigbee™ capable RF Transceiver
  • Regulated +3.3V power supply w/ indicator
  • Size 3.5 x 5.5 +5 -
  • +25VDC, 9VDC typical power input
  • Current Consumption: 100ma typical @ 9VDC input
下载连接:
MCF5213 评估板用户手册
GMT+8, 2025-3-11 13:13 , Processed in 0.114565 second(s), 15 queries , MemCache On.
