M5249C3 评估板提供了着手高性能嵌入式设计的很不错的工具。
With 8 MBytes of SDRAM, 2 MBytes of Flash, 10/100 BaseT ethernet connectivity, two serial ports, and access to the best-in-class ColdFire debug module. This complete package includes all the components for realizing an MCF5249 design quickly and easily.
Features
- MCF5249 running at 140 MHz, internal bus speed of 70 MHz
- Monitor/Debugger programmed on 2 MByte of Flash with 1.8 MBytes available for customer use
- On-board 10/100 BaseT ethernet conectivity via RJ-45 connector
- 4 channel DMA
- Dual programmable UARTs (universal asynchronous/synchronous receiver/transmitter) - 1 available for customer use
- Debug module interface connector (used with source level debuggers running on PC's)
- Serial cable (give access to ROM monitor which includes in-line assembler)
- All CPU signals available for user accessibility via two 120-pin expansion connectors
- Small form factor
- Power Requirements are +7 to +14 Volts DC regulated or unregulated (on board regulation to +5V, +3.3V, and +1.8V DC)
Kit Contains
- Printed Wiring Board Assembly, RE10811B Rev 1.1
- Cable: DB9 M/F Serial Data Cable
- Cable: DB25 M/F Parallel Port Interface Extension Cable
- Cable: ColdFire BDM (wiggler) cable
- Book: M5249C3 User's Manual
- Book: MCF5249 ColdFire Integrated Microprocessor User's Manual*
- Book: ColdFire Family Programmers Reference Manual Rev. 2
- Document: Technical Support contact info. for Freescale Semiconductor Products
- Tools: Metrowerks CodeWarrior evaluation CD, datasheet and quick start guide
- Tools: Various development tool vendor contacts, evaluations and/or datasheets*
* May be substituted with procurement and/or contact information if not available at kit assembly time.
下载连接:
M5249C3 参考设计手册 |
