查看: 322|回复: 0
MCF52210 演示版
发表于 2012-8-22 14:48:39 | 显示全部楼层 |阅读模式
M52210DEMO 是一个飞思卡尔 MCF52210 ColdFire微控制器的低功耗开发板。Application development is quick and easy with the included DB9 serial cable, integrated BDM, and USB cable. A 128 MB flash-drive and 6-in-1 USB cable provide support for the integrated USB PHY.CodeWarrior Development Tools provide application development and debug support.The integrated BDM allows easy application development and debugging. An optional BDM port compatible with standard ColdFire BDM / JTAG interface cables and hosting software is also provided but not installed.
Features
  • MCF52210 microcontroller, 80 LQFP
  • Integrated USB BDM
  • Super-Cap Backup for VSTBY (not available on Rev A)
  • 48 MHz XTAL
  • 40 pin I/O port
  • miniUSB Port
  • BDM / JTAG Port (not installed)
  • ON/OFF Power Switch w/ LED indicator
  • RESET switch w/ indicator
  • Power Input Selection Jumper
    • Power Input from USB BDM
    • Power input from miniUSB
    • Power Input from on-board regulator
    • Power Input from terminal block
    • Power from connector J1
  • User Features
    • 3-axis Accelerometer
    • 4 User LED's w/ enable
    • 2 User Push Switches
    • 5k ohm POT w/ enable
  • Connectors
    • RJ-45 Ethernet Connector
    • Type B USB connector
    • RS-232 Serial Port w/ DB9-S Connector
    • 2.0mm Barrel Power Input
    • 2pos, screw type, terminal block
下载连接:
M5211DEMO 硬件用户指南
GMT+8, 2024-11-27 04:01 , Processed in 0.105822 second(s), 15 queries , MemCache On.
