EVB9S08DZ128/60Clock module, crystal oscillator, and connector for providing an external clock sourceBDM connectorFour header connections with all MCU signals12 V DC barrel input connector (2.1 mm)Two banana input connectors (12 V DC and GND)Power on/off switchBuilt-in "USB to BDM Interface"Reset push-buttonFour additional push buttonsTwo potentiometersEight dip-switchesSeries of jumpers to connect/disconnect the above controlsOutputs section containing ten LEDS and relative jumpersCAN section that has CAN connector with two CAN transceivers (high speed and single wire) with series of jumpers to select the CAN physical layerLIN section with LIN connectors andh LIN enable jumper and a "WAKE" push buttonRS-232 section with two RS-232 connectorsSerial settings section containing two jumpers to select which transceiver is connected to microcontroller's shared TXD1 and RXD1 serial linesPrototype area
