查看: 344|回复: 0
MCF51QE128 评估板
发表于 2012-8-22 14:35:13 | 显示全部楼层 |阅读模式
EVBQE128 评估板用于评估、演示和调试飞思卡尔  Flexis QE128 微控制器MC9S08QE128和 MCF51QE128。The EVBQE128 can be used as a standalone application or can be controlled by a host PC via its built-in microDART™ interface.
Features
1. An “MCU” section containing:
  • An 80-pin LQFP socket accepting either the MC9S08QE128 or the MCF51QE128 microcontroller
  • A crystal oscillator, a provision for a clock module, a provision for a connector for providing an external clock source, together with jumpers to select the clock source
  • A BDM connector for in-circuit debugging/programming with an external instrument
  • A female header connectors with all of the MCU signals
2. A power supply section containing:
  • A 12 V DC barrel input connector (2.1 mm)
  • A four-way micro terminal block for providing specific power supplies and voltage references to the microcontroller
  • A jumper to select the power supply source (USB bus or barrel connector)
  • A power on/off switch
3. A built-in “microDART INTERFACE” section (with the main circuitry mounted on the back of the board) which allows the host PC to communicate with the microcontroller through a standard USB interface. Jumpers are present to configure this module. Thanks to the microDART in-circuit debugging firmware, BDM commands are sent to the target microcontroller through the USB bus. Additionally, a virtual COM port is automatically available over the same USB connection. This virtual COM port can be used by standard terminal programs, like HyperTerminal, to send/receive serial characters to/from the target microcontroller.4. An “I/O” section containing
  • A Reset push-button
  • Four additional push-button
  • One potentiometer
  • Eight dip-switches
  • A piezoelectric buzzer
  • A light sensor
  • A temperature sensor
  • Ten user LEDs
  • A circuitry for driving and external LCD
  • A series of jumpers to connect/disconnect the above controls to/from the microcontroller
5. An “RS-232” section containing two RS-232 connectors together with a jumper to enable the RS-232 communication6. A “SERIAL SETTINGS” section containing jumpers to select communication optionsKit Contains
  • The EVBQE128 evaluation board;
  • 80-pin LQFP MC9S08QE128 and MCF51QE128 microcontrollers;
  • A USB cable;
  • A pick-up vacuum pump;
  • A universal, 12 V DC power supply;
  • System software DVD-ROM, including CodeWarrior™ Development Studio;
  • A Quick Start Guide sheet.
下载连接:
QE 系列评估板用户手册
QE 系列评估板快速入门指南
GMT+8, 2024-11-27 04:04 , Processed in 0.108589 second(s), 15 queries , MemCache On.
