查看: 359|回复: 0
S08JM16 演示板
  • 签到天数: 11 天
    发表于 2012-8-22 13:38:07 | 显示全部楼层 |阅读模式
    DEMO9S08JM16是一个符合成本效益的快速评估MC9S08JM16的评估套件。The kit includes a DEMOJM base board and a MC9S08JM16 daughter card and can be used to demonstrate the features of the MC9S08JM16 device, starting with the on-chip USB 2.0 full-speed device controller and transceiver. The USB features are supported in hardware through a dedicated USB mini-AB connector and in software through the included complimentary USB-LITE stack by CMX. Built-in USB-BDM circuitry is available for debugging and programming, serial communication and simple logic analyzer.
    Features
    • On-board Logic Analyzer
    • On-board Virtual Serial Port
    • ON/OFF Power Switch w/ LED indicator
    • A 6VDC to 12VDC power supply input barrel connector
    • USB device mode and host mode support with Mini-AB USB connector
    • CAN Module with Enable
    • 3-axis Accelerometer with Enable
    • 8 User LED’s with Enable
    • 4 User Push Buttons with Enable
    • 1 Piezo Buzzer with Enable
    • I²C Pullups with Enable
    • 10K Ohm POT with Enable
    下载连接:
    S08JM16 演示板用户指南
    GMT+8, 2024-11-27 04:30 , Processed in 0.107193 second(s), 15 queries , MemCache On.
