查看: 327|回复: 0
MCF52277评估板
发表于 2012-8-22 13:25:14 | 显示全部楼层 |阅读模式
M52277 评估板是基于含eMAC的 V2 Coldfire 核 .This board is shipped with the MCF52277 populated to allow for evaluation of all of the functionality of this part.This board was designed as a validation platform with maximum flexibility. Where possible we've also designed for power and speed, but the primary goal of this system is flexibility.
Features
  • M52277 External Interfaces
    • On-board Sharp 240 x 320 color touch screen LCD panel
    • 60-pin external LCD connector
    • Synchronous Serial Interface (SSI) connected to audio CODEC
    • USB Support
      • MCF52277 on-chip OTG transceiver with device, host, and OTG support (mini-AB receptacle)
    • Crystal/clock
    • BDM/JTAG
    • Two UARTs
    • FlexBus
    • Timers
    • External interrupts
    • CAN support
      • External CAN transceiver (DB9 connector)
    • University Breakout Connector for serial interfaces (I²C, QSPI, GPIO, etc.)
  • Memory Subsystems
    • 32 M x 16 mobile DDR
    • 8 M x 16 NOR flash
    • 16 MB serial boot flash
  • Power
    • Inputs
      • 5 V input to the voltage regulator circuitry
    • Regulated on-board voltages:
      • 3.3 V - I/O voltage
      • 1.8 V - Mobile DDR and flash voltage
      • 1.5 V - MCF52277 core voltage
下载连接:
M52277EVB评估板用户手册
GMT+8, 2024-11-27 04:18 , Processed in 0.118268 second(s), 15 queries , MemCache On.
