查看: 303|回复: 0
MCF5282 LITE 评估板
发表于 2012-8-22 11:31:07 | 显示全部楼层 |阅读模式
M5282LITE评估板提供了着手高性能但低价格嵌入式网络设计的开发板。With 16 MBytes of SDRAM, 10/100 BaseT Ethernet connectivity, and a best-in-class ColdFire debug module, this complete package includes all the components to enable quick design support for the MCF5280, MCF5281, and MCF5282.This cost-sensitive development platform will be available in March along with RTOS, open source GNU tools, and open source TCP/IP stack.  This low cost hardware package bundled with its software and tools combine to provide a cost effective networking platform that can be up and running right out of the box with all the necessary components for application development.  Freescale also has the complete M5282LITEKIT that includes the M5282LITE evaluation board with the CE certifed power supply and a wiggler cable.
Features
  • 16M byte SDRAM, 2M byte Flash
  • 10/100 Ethernet PHY and RJ45 connector
  • DB-9 connector
  • Serial ports
  • 6 to 14VDC Input
  • Typical Operating Power: 400mA @ 66MHz (expected)
GMT+8, 2024-11-27 04:22 , Processed in 0.115741 second(s), 15 queries , MemCache On.
